Curiousone's avatar
Curiousone
localhost under "attached device"
I just want to know if the word "localhost" in the Attached Device Screen under Device Name is legit.  Is it?
I did not notice this before and it might have been there all this time BUT I just want to know if this is normal.
  • ElaineM
    Follow your suggestion.  I found what the problem is/was.  It was on another laptop where there was a private vpn (??) that was connected to the wifi.  This was  the source of my mysterious line item.  No problem with this connection.
    Feel much better now.  Thought it was an "invasion" of my wifi from an unknown source!!!!!
    Thank You Very Much
  • > I just want to know if the word "localhost" in the Attached Device
       Define "legit".  What are the other data in that entry in your
    Attached Devices list?
       Normally, "localhost" is associated with the loopback address,
    127.0.0.1, but, at the risk of confusion, anyone could use it.
    • Curiousone's avatar
      Curiousone
      I am asking if the word "localhost" should be listed or not.  The other items listed are my laptop name, my cell phone (when it is turn-on, my printer and if my wife is using her laptop, her laptop name is listed also.
      I could identify each line item that use the wi-fi except for "localhost."  Perhaps this is "normal" but I don't know.
      • antinode's avatar
        antinode
        Guru
           I'm asking what the other data (IP address, ...) are for that entry,
        not the names of the other entries.
           Without more data from that entry, neither do I.
