Curiousone
Sep 20, 2017Aspirant
localhost under "attached device"
I just want to know if the word "localhost" in the Attached Device Screen under Device Name is legit. Is it? I did not notice this before and it might have been there all this time BUT I just ...
- Sep 26, 2017
ElaineM
Follow your suggestion. I found what the problem is/was. It was on another laptop where there was a private vpn (??) that was connected to the wifi. This was the source of my mysterious line item. No problem with this connection.
Feel much better now. Thought it was an "invasion" of my wifi from an unknown source!!!!!
Thank You Very Much
Curiousone
I am asking if the word "localhost" should be listed or not. The other items listed are my laptop name, my cell phone (when it is turn-on, my printer and if my wife is using her laptop, her laptop name is listed also.
I could identify each line item that use the wi-fi except for "localhost." Perhaps this is "normal" but I don't know.
antinode
Sep 20, 2017Guru
I'm asking what the other data (IP address, ...) are for that entry,
not the names of the other entries.
Without more data from that entry, neither do I.
- CuriousoneSep 20, 2017Aspirant
- ElaineMSep 21, 2017NETGEAR Employee Retired
The Device Name listed is whatever hostname that is saved on the device.
Look for the device that has the IP address of 192.168.1.6 and check its hostname.
- CuriousoneSep 26, 2017Aspirant
ElaineM
Thank You Very Much
