Curiousone
Sep 20, 2017Aspirant
localhost under "attached device"
I just want to know if the word "localhost" in the Attached Device Screen under Device Name is legit. Is it? I did not notice this before and it might have been there all this time BUT I just ...
- Sep 26, 2017
ElaineM
Follow your suggestion. I found what the problem is/was. It was on another laptop where there was a private vpn (??) that was connected to the wifi. This was the source of my mysterious line item. No problem with this connection.
Feel much better now. Thought it was an "invasion" of my wifi from an unknown source!!!!!
Thank You Very Much
antinode
Sep 20, 2017Guru
Define "legit". What are the other data in that entry in your
Attached Devices list?
Normally, "localhost" is associated with the loopback address,
127.0.0.1, but, at the risk of confusion, anyone could use it.
