Euther
Feb 17, 2018Aspirant
Loss of bandwidth ... What should I check please?
Good day, I just upgraded my internet service to Xfinity Blast! Pro... 250/10 Mpbs. Seems if I put a device through my SRX5308, I can not break 100Mbps. - I have upgraded the firmware to versio...
Euther
Opps. Can't find the delete button
- DaneAFeb 19, 2018NETGEAR Employee Retired
Hi Euther,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. Is the SRX5308 connected to a modem-only device or to a modem-router provided by Xfinity Blast? If ever the device provided by Xfinity Blast is a modem-router combination, I suggest you to set the modem-router to full-bridge mode so that it will be a modem-only device. This will make the SRX5308 the main router of your network wherein the Public WAN IP Address will be registered to it.
b. Since you have upgraded the firmware of the SRX5308 to v4.3.5.3, did you perform a factory reset after upgrading the firmware? If not yet, I suggest you to factory reset the SRX5308 then reconfigure the settings from scratch and observe if same problem occurs.
DaneA
NETGEAR Community Team
- EutherFeb 24, 2018Aspirant
DaneA,
Thank you for replying. I do appreciate it! Thank you for the warm welcome, too!
[Q] Is the SRX5308 connected to a modem-only device or to a modem-router provided by Xfinity Blast?
[A] The SRX5308 is connected directly to a ARRIS SURFboard SVG2482AC Eth Port 1.
[Q] I suggest you to set the modem-router to full-bridge mode so that it will be a modem-only device
[A] I see on the "At a glance" web page that Bridge Mode = Disabled. Is this what you are referring to?
When I click the enable button, this pops up: "Enabling Bridge Mode will disable Router functionality of gateway and turn off the private Wi-Fi network. Are you sure you want to continue?" I have the wireless disabled at this time, so I dont know if this is a big deal or not. Also, I have phone service connected to this device. Will this be impacted if I enable this option? Thoughts?
[Q] Since you have upgraded the firmware of the SRX5308 to v4.3.5.3, did you perform a factory reset after upgrading the firmware?
[A] I did not. Is there a preferred link I should look at for instructions on how to do this?
I am assuming the following:
Backup / Restore Settings
1) Save a copy of current settings
2) Revert to factory default settings. Click the "Button". I will need to find out the default name/password.
3) Restore saved settings from file
Yes? I have some LAN/WAN Rules too... anything special I need to do regarding those?
Thank you again!!
Perform a factory reset after upgrading the firmware?
Via, Backup / Restore Settings
4) Rebooted.
5) Disabled all FW rules
6) Speed Test Results (Same Server): 60Mbps (D) / 11Mbps (U)
- DaneAMar 07, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- EutherMar 16, 2018Aspirant
Hi DaneA ... I was out of town on business... Sorry for the delayed reply!!
I turned on or Enabled that setting... But still not getting the expected speed I am paying for. I Hope there is something else to try, and I am thinking about removing the netgear device. :(
AGAIN, BIG Thank you for helping me!!!
Euther
