netgearneophyte
Jan 16, 2012Novice
Many FVS318v3 Log Entries: UDP packet "Access Policy not found"
My simple office setup is as follows: ISP <=> Office Building Cable Modem/Router (Shared) <=> Office Tenants (I'm one of many)... ...my FVS318v3 <=> my single Win7 laptop and HP printer connected ...
netgearneophyte
Jan 17, 2012Novice
Thanks for your help. I searched a bit today for the term, "tent router," so as not to waste your time, but there's not much out there (at least that I can understand). A few words, or link, on this will be appeciated.
jmizoguchi wrote: since you are sharing with entire suite so looks like WAN is all private IP, seems to make sense .
there must be a device behind the WAN side (cable modem> tent router) which are broadcasting the traffic
That's actually an option assuming I understand you correctly, having been already told the building is set up for the cable company to jack directly into individual offices (for what can't be much more than I'm paying now). Then it would be ISP <-> FVS318v3 <-> my stuff.
adit wrote: You'll see goofy traffic come through to the logs when you have private IP's on the WAN.
I would get a public IP if possible.
