RRHNL
Mar 10, 2018Initiate
Memory leak
I have located a Memory leak in my system associated with the following Greenbow driver(s) with tags identified via Poolmon.exe as TgBj and TgBi. I have windows 10, 64bit. These drivers are filling u...
mattcoz
May 22, 2018Aspirant
I have this exact same problem! Were you ever able to find an update?
- RRHNLMay 22, 2018InitiateNo. Netgear support didn’t respond as I had hoped. They offered to work with me to get connected which was not the issue, and wanted me to do copious testing to which I declined as I am now CFO of a company (with some old IT knowledge) & I wanted them to research & fix. So all I do now is watch my non paged pool and when it gets to around 3-4gb I reboot. I also exit my rdp session on the remote computer when I’m done and sometimes close the tunnel. This stops the leak from growing overnight eg. Overall I wish they would patch & fix, but they didn’t seem interested enough or didn’t understand the issue was that I was reporting a flaw.
- mattcozMay 24, 2018Aspirant
Damn. I think we're better off going through Greenbow as it is their driver that is causing the problem. Netgear is just licensing it for their use. I downloaded their latest version which had a slightly newer driver and I'm doing some testing. So far my NP pool hasn't grown to immense size, but those tags are still at the top and growing.
- mattcozMay 25, 2018Aspirant
They told me to go through Netgear support, of course.
