johnjvictor
Feb 28, 2017Aspirant
Migrate FVS336GV3 settings to SRX 5308
I plan to replace my FVS336V3 with an SRX5308 to get greater Lan-to-Wan throughput. Does anyone know if I can install the FVS settings on to the SRX as the first step of the configuration?
- Mar 01, 2017
Thank you. Sounds like I need to plan for a manual entry of the settings.
johnjvictor
Mar 01, 2017Aspirant
JohnRo
Mar 01, 2017NETGEAR Employee Retired
Hi johnjvictor,
Yes. For now that's the only thing we can do. I'd do screenshots instead of writing everything down. :)
Have a great day.
Thanks,
