adamberns
May 02, 2016Follower
Multip Public IPs 1 to 1 NAT
From my ISP I have multiple Public IP address, for example 50.0.37.40-43. I would like to map each one of those to an internal IP address. For example 50.0.37.40 would map to internal address of 10.1...
DaneA
May 04, 2016NETGEAR Employee Retired
Hi adamberns,
Welcome to the community! :)
I'm afraid that what you want to accomplish is not possible with the FVS318Gv2. However, it might be possible with the FVS336Gv3 because there is an option that you could add a secondary WAN IP address(es). You can assign these secondary WAN IP address(es) when you configure firewall rules as a NAT IP address for a LAN WAN outbound firewall rule or as a WAN destination IP address for a LAN WAN inbound firewall rule. For more details, kindly access the FVS336Gv3 user manual here.
DaneA
NETGEAR Community Team
