starion
Mar 02, 2013Aspirant
Multiple static IP's on FVS-318N
I have multiple static IP's from my internet provider. At the moment, I have various publicly available servers simply plugged into a five port hub off the cable modem and one of the static IP's set...
jmizoguchi
Apr 08, 2013Virtuoso
If using inbound/outbound rules with specifying public IP is not going to work then you will need to use classical routing feature in the router
