Noreadib
Apr 24, 2017Aspirant
need advise to configure SRX5308 SSL VPN access
Dear Mates, I am new to the SRX5308, I have installed an SRX5308 behind an ADSL2+ modem/Router in a small office and trying to configure SSL VPN for remote access. I have created the portal layou...
DaneA
Apr 27, 2017NETGEAR Employee Retired
Hi Noreadib,
Welcome to the community! :)
Let me share the article below and it might help setting up SSL VPN on your SRX5308:
Be reminded to use the appropriate Operating System and browser to connect to the SSL VPN. Kindly read the article below:
ProSAFE: SSL VPN Compatibility Matrix (by OS and Browser)
DaneA
NETGEAR Community Team
- NoreadibApr 27, 2017Aspirant
Hi Dane,
Thank you for your reply. It seems that the clients are not supported in the matrix. Thus, I'm looking at the IPSec configuration. https://kb.netgear.com/24245/ProSAFE-VPN-Client-Client-to-Box-Configuration
I've followed every step of the above but still not able to connect. Below is the logs from the session.
20170428 12:28:10:109 Upgrading configuration...
20170428 12:28:10:109 Reading configuration...
20170428 12:28:10:112 IKEv1 configuration detected
20170428 12:28:10:112 No IKEv2 configuration
20170428 12:28:10:112 Default IKE daemon is removing SAs...
20170428 12:28:10:113 No SSL configuration
20170428 12:28:10:113 Default reinitializing daemon
20170428 12:28:10:537 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) is opening.
20170428 12:28:10:540 Default ike_phase_1_initiator_send_SA: section [3DES-Auto-GRP2] has unsupported attribute(s)
20170428 12:28:10:540 Default exchange_run: doi->initiator (0119ABA0) failedAny advise to move forward is appreciated.
