Noreadib
Apr 24, 2017Aspirant
need advise to configure SRX5308 SSL VPN access
Dear Mates, I am new to the SRX5308, I have installed an SRX5308 behind an ADSL2+ modem/Router in a small office and trying to configure SSL VPN for remote access. I have created the portal layou...
DaneA
Apr 27, 2017NETGEAR Employee Retired
Hi Noreadib,
Welcome to the community! :)
Let me share the article below and it might help setting up SSL VPN on your SRX5308:
Be reminded to use the appropriate Operating System and browser to connect to the SSL VPN. Kindly read the article below:
ProSAFE: SSL VPN Compatibility Matrix (by OS and Browser)
DaneA
NETGEAR Community Team
Noreadib
Apr 27, 2017Aspirant
Hi Dane,
Thank you for your reply. It seems that the clients are not supported in the matrix. Thus, I'm looking at the IPSec configuration. https://kb.netgear.com/24245/ProSAFE-VPN-Client-Client-to-Box-Configuration
I've followed every step of the above but still not able to connect. Below is the logs from the session.
20170428 12:28:10:109 Upgrading configuration...
20170428 12:28:10:109 Reading configuration...
20170428 12:28:10:112 IKEv1 configuration detected
20170428 12:28:10:112 No IKEv2 configuration
20170428 12:28:10:112 Default IKE daemon is removing SAs...
20170428 12:28:10:113 No SSL configuration
20170428 12:28:10:113 Default reinitializing daemon
20170428 12:28:10:537 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) is opening.
20170428 12:28:10:540 Default ike_phase_1_initiator_send_SA: section [3DES-Auto-GRP2] has unsupported attribute(s)
20170428 12:28:10:540 Default exchange_run: doi->initiator (0119ABA0) failed
Any advise to move forward is appreciated.
