RoyDerksen
Apr 22, 2017Aspirant
Netbios wont work Box to Box VPN SRX5308 to FVS318N
Hi all, Did setup a box to box IPSec VPN. The SRX5308 has WAN ip and the FVS318N is behind NAT but DMZ. Its working so far so good, i can ping other devices but i cant acces any HTTP or HTTPS ex...
DaneA
Apr 27, 2017NETGEAR Employee Retired
Hi RoyDerksen,
Welcome to the community! :)
Kindly answer the questions below:
a. Is the LAN subnet of the SRX5308 different from the LAN subnet of the FVS318N?
b. Is the WINS server directly connected to the SRX5308 or to the FVS318N?
c. Is NetBIOS enabled on the VPN Policy of both SRX5308 and FVS318N?
d. Have you tried to delete the existing IKE / VPN Policies then re-create it using the VPN Wizard on both SRX5308 and FVS318N?
e. What is the current firmware version of both SRX5308 and FVS318N?
f. Is your NAS a NETGEAR device? If yes, what is the model number of it?
It would be best if you post a diagram of your detailed network setup as well as the settings of the IKE / VPN policies on both VPN firewalls.
DaneA
NETGEAR Community Team
DaneA
Apr 30, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
