RoyDerksen
Apr 22, 2017Aspirant
Netbios wont work Box to Box VPN SRX5308 to FVS318N
Hi all, Did setup a box to box IPSec VPN. The SRX5308 has WAN ip and the FVS318N is behind NAT but DMZ. Its working so far so good, i can ping other devices but i cant acces any HTTP or HTTPS ex...
DaneA
Apr 30, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
NETGEAR Community Team
DaneA
May 09, 2017NETGEAR Employee Retired
I apologize for this is the only time I got back on this. Here are my follow-up questions:
a. Is the WINS server configured to the client on the FVS318N side also?
b. Can you confirm if NetBIOS does resolve between clients (such as PCs) on the same LAN? For example: PC1 to PC2 within the FVS318N LAN or PC1 to PC2 within the SRX5308 LAN.
DaneA
- RoyDerksenMay 11, 2017Aspirant
No problem, struggeling almost a mounth or 2 with this isue.
a. Yes, IP's are manual added to the wins server and seen as active.
b. Yes, both sides netbios works fine on all devices.
Maybe helps this: When i'm at work and i make a PPTP connection to SRX5308 with my phone (connected at the WiFi of the FVS318N) than all works fine, but only on my phone. When i use my laptop on PPTP dito.
Regards
- RoyDerksenMay 15, 2017Aspirant
Nevermind this isue.
After latest firmware update the FVS318N wont boot up anymore.
Test led stays on. :-(
- DaneAMay 16, 2017NETGEAR Employee Retired
Have you tried to perform a factory reset on the FVS318N? If yes and still the test LED is lit up, I suggest you to open a chat / online case with NETGEAR Support. Let them know what happened to your FVS318N. Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of the FVS318N on the online case for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
