MiDaSecurity
Feb 17, 2019Aspirant
Netgear BR500 big problem
Hello,
I'am Mike and i've got a big major problem with the br500.
1: it takes to long for the divece to come on insight.
2: it loses the internet connnection.
3: it loses insight connecti...
DaneA
Feb 18, 2019NETGEAR Employee Retired
Hi MiDaSecurity,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. Is the modem where the BR500 is directly connected to a modem-only device or a modem-router combo?
b. Disconnect the BR500 from the modem then connect a PC directly to the modem. Are you able to access the internet just fine?
c. If ever you are using the Insight App, what version are you using? Make sure you are using the latest version of the Insight App which is version 5.5 which is available for Android and iOS.
DaneA
NETGEAR Community Team
- MiDaSecurityFeb 18, 2019Aspirant
Hey Dane,
Tnx for the info.
The problem is deployed by support today and last week. After monitoring the BR500 today we concluded that the problem is in the hardware.
So for now the br500 is going to be replaceb by an new one.
All the info you gave me i'll ready did this also factory reset and backwords startups as also stand alone. Nothing worked.
The next step now is waiting for a new one and then the following step will be maybe to set up the providers router.
- MrJoshWFeb 19, 2019NETGEAR Employee Retired
Thanks for the update. Please keep us updated if you have any further issues with the replacement unit and I will be more then happy to help troubleshoot the devices issues.
- Jan 04, 2019Retired_Member
- Apr 02, 2019Retired_Member
