MiDaSecurity
Feb 17, 2019Aspirant
Netgear BR500 big problem
Hello,
I'am Mike and i've got a big major problem with the br500.
1: it takes to long for the divece to come on insight.
2: it loses the internet connnection.
3: it loses insight connecti...
MiDaSecurity
Feb 25, 2019Aspirant
Update****
For now the retailer is sending a new BR500. So now we will wait for the new one to install.
Are there any TIPS for installing the BR500?
Kind regards
Mike
MrJoshW
Mar 11, 2019NETGEAR Employee Retired
Hello,
You can always refer to the installation manual when setting up the devices. One tip to point out would be if adding two or more BR500 devices into a VPN group please make sure your VLAN1 subnet range is on different subnet ranges to avoid possible IP conflicts between the devices.
https://www.downloads.netgear.com/files/GDC/BR500/BR500_IG_EN.pdf
- Jan 04, 2019Retired_Member
- Apr 02, 2019Retired_Member
