ACB-Holmen
Nov 26, 2020Aspirant
Netgear ProSafe VPN Client
I am using the Netgear ProSafe VPN client to connect remotely to the network. This works so far. Now I have a new laptop and I am not able to activate the Netgear VPN software. Always says "internal ...
JohnC_V
Nov 27, 2020NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues applying for your VPN Client License. Do you see any error code on your VPN client? May you be able to send me the license key via private message so that we could check it on our end?
John
NETGEAR Community Team
ACB-Holmen
Dec 02, 2020Aspirant
Hi John,
it says error code 70 - internal error.
Please see attached screen shot - in German I am afraid. Screen shot
- JohnC_VDec 03, 2020NETGEAR Employee Retired
Please try to disable first the firewall and the anti-virus of your PC then try to activate the license again. Please also send me the license key via private message so that we can check it on our end and have it reset.
John
- ACB-HolmenDec 03, 2020Aspirant
Hi John,
did that already with disabling firewall and antivirus. Also used the admin account. No difference. Also install-user account makes it no better.
The license key I will send by private message
Arnd
As per checking, the 5-licenses that you have is still unused. This license is only applicable to VPN Client Lite and not to VPN Client Professional. Please try to use the VPN Client Lite or vice versa.
John
