ExpTechs's avatar
ExpTechs
NETGEAR ProSafe Router
I purchased the Netgear ProSafe FVS318N VPN Router for our company to help with pop-ups on our network.  When trying to configure it, I found out that it does not allow spaces in the SSID?  We have way too many devices to go and reconfigure each one.  Does Netgear make a ProSafe router that does allow spaces in the SSID??  Thank you for any help you can give.
Rick
  • JohnRo's avatar
    JohnRo
    Jul 31, 2015
    Hello ExpTechs,
    Yes, you can disable the wireless function of the FVS318N or you can just turn off the SSID broadcast. There is this thread here where some users talked about disabling the wireless fuinction totally, you can probably get some ideas. Here's where you will change the settings of the wireless network -also has the option to totally disable it.
    Click here for the reference manual, you can find the wireless configuration starting page 4.
    What kind of pop-ups do you get by the way? Can you tell me a little bit more about your network diagram? How is everything connected as of the moment?
    I'll look forward to your response.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello ExpTechs,
    Welcome to the community!
    Both of our prosafe routers FVS318N and SRXN3205 only supports Alphanumeric characters along with underscores but not spaces. However, we do have wireless access points that you can use. I have tested most of our AP's such as the WNDAP360 and I can use spaces. You may check the product specs below:
    http://www.downloads.netgear.com/files/GDC/datasheet/en/WNDAP360.pdf
    I hope this information can help you fix your issue. I'll be looking forward to your reply.
    Thanks,
    • ExpTechs's avatar
      ExpTechs
      H JohnRo,
      Thank you for the quick responce.  We have a Netgear wireless router  now that does that for us.  The problem is we are getting inundated with pop-ups and re-directs when connected to our network
      and were told a ProSafe router would help block that?  It has to be our network because when we take our laptops (and phones) and connect to other networks (home, etc...), the pop-ups stop?
      Would it be possible to connect the ProSafe and disable wireless on it, then have the current wireless "feed" the wireless network?  Maybe you would have a better solution?  Thanks for you help.
      Rick
      • JohnRo's avatar
        JohnRo
        Hello ExpTechs,
        Thanks,
