tkershaw
Nov 18, 2016Aspirant
Netgear SSL VPN maximum limit on number of active tunnels has been reached on netgear vpn
We have a working SSL VPN setup and has been for some time now. Is there any way to clear active tunnels from the admin without having to do a power off reset? I tried a software reset first but that...
Dan_Z
Nov 21, 2016NETGEAR Expert
Hello,
Welcome to the community!
To clear active tunnels,can go to VPN->Connection Status->SSL VPN Connection Status,click Disconnect button.
Thanks.
- tkershawNov 29, 2016Aspirant
Yes, I tried that but no connections were showing to disconnect. I did find out the user was not closing the VPN properly after his remote control session timed-out or concluded; so he was admonished & re-educated on that. A power-off cycle of the SRX5308 cleared the error and the slow response times - crude but effective - though not ideal during the day when internet & email are being used by the staff.
- Dan_ZNov 30, 2016NETGEAR Expert
Hi tkershaw,
Thanks very much for your feedback.
I tried to do the case, but didn't see the issue.After click "Disconnect" button,the user record will disappear.
How much users did you connect?Thanks,
Dan
- tkershawDec 05, 2016Aspirant
Generally only one user logs in using SSL connection. He was not closing the tunnel properly; though the Netgear router should have timed-out and closed the tunnel unless he re-established a new tunnel right away... I had to power cycle the router to clear the improperly active tunnels that no-one was using.
