tkershaw
Nov 18, 2016Aspirant
Netgear SSL VPN maximum limit on number of active tunnels has been reached on netgear vpn
We have a working SSL VPN setup and has been for some time now. Is there any way to clear active tunnels from the admin without having to do a power off reset? I tried a software reset first but that...
Dan_Z
Nov 30, 2016NETGEAR Expert
Hi tkershaw,
Thanks very much for your feedback.
I tried to do the case, but didn't see the issue.After click "Disconnect" button,the user record will disappear.
How much users did you connect?
Thanks,
Dan
tkershaw
Dec 05, 2016Aspirant
Generally only one user logs in using SSL connection. He was not closing the tunnel properly; though the Netgear router should have timed-out and closed the tunnel unless he re-established a new tunnel right away... I had to power cycle the router to clear the improperly active tunnels that no-one was using.
- Dan_ZDec 05, 2016NETGEAR Expert
Hi tkershaw,
I tried it according to your description.If the ssl vpn timeout or do not closing the tunnel properly.
The ssl vpn user will disappear automation under SSL VPN Connection Status page.
Which brower do you use?Which version of SRX5308 do you use?Thanks,
Dan
