pgupta's avatar
pgupta
Follower
Sep 03, 2019
Netgear VPN Client Activation on another computer
I need to activate my vpn lite client on new computer. The old one is dead and I did uninstall it cleanly from the old one. Hoe can i do this? Thanks
  • DaneA's avatar
    DaneA
    Sep 04, 2019
    @pgupta,
    I just got an update from the higher tier of NETGEAR Support.  As per the higher tier of NETGEAR Support, your VPN Lite license key has been reset.  You can now register your VPN Lite license key to your new computer.
    Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
