pgupta
Sep 03, 2019Follower
Netgear VPN Client Activation on another computer
I need to activate my vpn lite client on new computer. The old one is dead and I did uninstall it cleanly from the old one. Hoe can i do this? Thanks
- Sep 04, 2019
I just got an update from the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, your VPN Lite license key has been reset. You can now register your VPN Lite license key to your new computer.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Sep 04, 2019NETGEAR Employee Retired
Welcome to the community! :)
I got your private message. I will send a request to the higher tier of the NETGEAR Support Team to reset your VPN Lite license key. I will post here once I got a feedback.
DaneA
DaneA
DaneA
