hgrossman
Aug 04, 2017Aspirant
Netgear VPN Client Professional Licenses
I purchased 5 licenses and they were all installed. One of the people left the organization but never had the software uninstalled. Is there any way to find out who is holding those 5 licenses? ...
- Aug 11, 2017
I already sent you a pm about the information that you needed. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Aug 05, 2017NETGEAR Employee Retired
Hi hgrossman,
For us to find out who it is, we need the license key number so that we can try to check that on our database. You may send it to me via pm.
Welcome to the community!
hgrossman
Aug 07, 2017Aspirant
Thanks.
How do I PM you from this blog?
- JohnC_VAug 11, 2017NETGEAR Employee Retired
