dxm
Aug 27, 2016Tutor
New Firmware fvs318n 4.3.4-1 crashing at install 082716
This latest firmware update is crashing at install. I've downloaded it twice, I've tried the install from 2 different systems using 3 different browsers on each system, IE and newest Chrome and the n...
DaneA
Aug 31, 2016NETGEAR Employee Retired
Hi dxm,
I just want to follow-up on this.
DaneA
NETGEAR Community Team
- dxmSep 02, 2016Tutorc yesb no, i'll wait for the next revision before thatSorry for the late reply, GOt an error back from emaila 4.3.3-8
d unzipped, never install from a zip file.
- DaneASep 04, 2016NETGEAR Employee Retired
Hi dxm,
About your answer on my 2nd question, what do you mean by "you'll wait for the next revision"? Does it mean that you will wait for another firmware release?
You may try to upload the latest firmware v4.3.4-1 via TFTP. Kindly access the article below on how:
How to upload firmware to a NETGEAR router using TFTP
If you are not confident in doing the steps on how to upload the firmware using TFTP by yourself, you may open an online case with NETGEAR Support for assistance.
DaneA
- DaneASep 07, 2016NETGEAR Employee Retired
Hi dxm,
I just want to follow-up on this. Were you able to try to upgrade the firmware of the FVS318N using TFTP? Or, have you sought assistance from NETGEAR Support?
DaneA
- dxmSep 08, 2016Tutor
Hi DaneA
I haven't tried that. I'll look into it. Thanks for the suggestion. I'll let you know how it turns out.
