MR2024
Sep 19, 2024Aspirant
Old Netgear Prosecure UTM5 question
Hi everyone So we have an old Netgear Prosecure UTM5 firewall sitting in a segmented network My problem is that i can not get a NAT rule between the WAN and LAN ports to work(It seems this model do...
- Sep 24, 2024
Hello MR2024
I understand. If you have already tried that and are confident it was done correctly but are still experiencing the same results, it seems that the unit may need to be retired.
Have a lovely day,
Erwin
Netgear Team
MR2024
Thanks for your reponse
I am sorry for not being clear on this, I have done this, to be exact, i created a Service with the ports, and then created a rule from WAN->LAN, problem is, it's not working, I tested this by trying to : Telnet <LAN ip> port, which times out, and i can not figure out why, as i mentioned the Traffic Under Monitoring on this unit uses Flash so that is gone, and the logs do not work either, there is a Log Query function, but the log is empty for some reason
Regards
ErwinL
Sep 24, 2024NETGEAR Moderator
Hello MR2024
Have a lovely day,
Erwin
Netgear Team
