BobC99
Jul 17, 2016Tutor
Ping Local IP devices
Is it possible to Ping local connected IP addresses on different VLAN/subnets connected to the LAN ports, for example (192.168.0.5), from the FVS336Gv2 Web Interface while connected remotely? This wo...
- Jul 19, 2016
I don't see the "Accepted Solution" button any where on this message board,, where is it??
DaneA
Jul 17, 2016NETGEAR Employee Retired
Hi BobC99,
If I got your concern correctly, you will remotely connect to the web-GUI of the FVS336Gv2 from outside your network then you will ping a local IP address via Monitoring > Diagnostics on the web-GUI of the FVS336Gv2, am I right? If ever I am right, I believe this is possible.
DaneA
NETGEAR Community Team
- BobC99Jul 17, 2016Tutor
Yes correct
- DaneAJul 18, 2016NETGEAR Employee Retired
Hi BobC99,
Just want to follow-up on this. Were you able to remotely connect to the web-GUI of the FVS336Gv2 from outside your network then ping a local IP address via Monitoring > Diagnostics on the web-GUI of the FVS336Gv2?
DaneA
- BobC99Jul 18, 2016Tutor
Yes it worked for all my VLAN, thank you. The Select Local Gateway needs to be set to default, not WAN1 or WAN2.
