BobC99
Jul 17, 2016Tutor
Ping Local IP devices
Is it possible to Ping local connected IP addresses on different VLAN/subnets connected to the LAN ports, for example (192.168.0.5), from the FVS336Gv2 Web Interface while connected remotely? This wo...
- Jul 19, 2016
I don't see the "Accepted Solution" button any where on this message board,, where is it??
DaneA
Jul 17, 2016NETGEAR Employee Retired
Hi BobC99,
If I got your concern correctly, you will remotely connect to the web-GUI of the FVS336Gv2 from outside your network then you will ping a local IP address via Monitoring > Diagnostics on the web-GUI of the FVS336Gv2, am I right? If ever I am right, I believe this is possible.
DaneA
NETGEAR Community Team
BobC99
Jul 17, 2016Tutor
Yes correct
- DaneAJul 18, 2016NETGEAR Employee Retired
Hi BobC99,
Just want to follow-up on this. Were you able to remotely connect to the web-GUI of the FVS336Gv2 from outside your network then ping a local IP address via Monitoring > Diagnostics on the web-GUI of the FVS336Gv2?
DaneA
- BobC99Jul 18, 2016Tutor
Yes it worked for all my VLAN, thank you. The Select Local Gateway needs to be set to default, not WAN1 or WAN2.
- DaneAJul 19, 2016NETGEAR Employee Retired
Hi BobC99,
I'm glad that it worked. :)
Since your concern is resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
