BobC99
Jul 17, 2016Tutor
Ping Local IP devices
Is it possible to Ping local connected IP addresses on different VLAN/subnets connected to the LAN ports, for example (192.168.0.5), from the FVS336Gv2 Web Interface while connected remotely? This wo...
- Jul 19, 2016
I don't see the "Accepted Solution" button any where on this message board,, where is it??
DaneA
Jul 19, 2016NETGEAR Employee Retired
Hi BobC99,
I'm glad that it worked. :)
Since your concern is resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
BobC99
Jul 19, 2016Tutor
- DaneAJul 19, 2016NETGEAR Employee Retired
Hi BobC99,
It seems that you have already clicked “Accepted Solution” on your recent reply since it is highlighted in green. I suggest that you kindly select the appropriate reply as the “Accepted Solution.” :)
Cheers,
DaneA
- BobC99Jul 19, 2016Tutor
I clicked on the accepted solution button at the bottom of the page. I do not see anymore accepted solution buttons
Hi BobC99,
Is it possible for you to unclick it then mark the appropriate reply as the Accepted Solution? However, if that is not possible then its alright to just leave it that way. :)
DaneA
