tomtorre's avatar
tomtorre
Port Forwarding HELP needed on SRX5308 for Arlo System
I am looking for a detailed procedure, step by step, on how to Open Ports 443 & 80 - I am totally lost here. I tried following the instructions for Firewall Protection / Inbound Rules (Port Forwarding) on Page 140 of the SRX5308 Reference Manual but I'm just not getting it.
I just purchased (2) Arlo Netgear 5 Camera Systems but won't be able to view any video without these 2 ports Open
Any help would be most appreciated
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi tomtorre,
    Welcome to the community! :smileyhappy:
    Let us isolate the problem.  Kindly answer the questions below:
    a. Did you encounter any error message?  If yes, what does the error message says?
    b. What is the current firmware version of the SRX5308?
    c. I believe you have a modem where the SRX5308 is connected to, is your modem a modem-router combination or a modem-only device?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
    • tomtorre's avatar
      tomtorre
      Thanks for the reply
      A) I am not getting any error messages, I am just trying to be proactive here.  The Arlo Netgear Security Camera System will arrive today and I noticed on the Arlo website that ports 443 & 80 must be OPEN in order to stream the Arlo Camera Video to any Smartphone or the Arlo Web App.
      After searching this community I found a video that shows how to Add a Custom Security Services, so I set up 2 New Ones:
      Name - Type - Start Port - Finish Port
      ArloONE - TCP - 80 - 80
      ArloTWO - TCP - 443 - 443
      I think this is correct so far but I think I have to add these 2 services to Firewall Rules, I haven't so far, I think it's best to wait for the Arlo System to arrive
      B) Latest Bios, 4.3.3-6 is installed on the SRX5308
      C) I have a Cable Modem from my ISP and then the SRX5308 is Behind That - this would be the 1st time I ever had to creat Firewall Rules so pardon any ignorance to setting things up.
      I appreciate your response
      tomtorre
      • DaneA's avatar
        DaneA
        Hi tomtorre,
        I agree that we should wait for the Arlo units to arrive.  Then, you can set Inbound firewall rules for the Arlo units after it has been set up.
        DaneA
ProSupport for Business
