  • it was 5000 range ports.
    forgot, should not matter. isp is dsl? PPPoA?
  • if it is PPPoE then you should able to get bridge mode
    have not clue to your ISP but you want PPPoE authentication at FVS will be nice
    There are few setting were you can authenticate at DSL and pass through traffic. I think NAT is enabled on DSL unit that is causing since passing FVS works.
    you issues is more on ISP provided device settings then FVS
  • This evening i check if is real pppoe because i not insert any user or pass on the isp modem/router.
    The nat is enabled on dsl unit (static nat to 192.168.1.2)
    There'isnt a way to use port forwarding with double nat?
  • I solved with upnp on FVS, the server has configured the ports on the router and now work.
    Thanks
  • upnp are mostly for outbound needs but if you disable upnp and works then that is great.
    sometime it can create an issues
  • Thanks jmizoguchi but upnp are my only WAS, the isp can't do e wouldn't do anything for help me.
    If are disable upnp the ports remain closed.
    A this moment are my only solution.
    Thanks
ProSupport for Business
