opeinado
Jun 17, 2016Aspirant
port forwarding on FVS336gv3
I migrated from a sonicwall to Netgear FVS336Gv3, I´m configuring port fordwarding to permit RDP (in a special port 3839) and NAS (8080). I created a Service for each port, then created a service ...
- Jun 30, 2016Have you checked the network settings of the client? Check especially default gateway but also things like firewall. An incorrect set default gateway = works locally but not from Internet.
You can also run wireshark on the client to make sure traffic hits it. The log indicates that the message is being forwarded, the fact that port testers show it as offline means that nothing responds on that port. Which is likely to be an issue on the client rather than he firewall. Packet captures would be able to prove this; do a LAN packet capture on the fvs336gv3 from the diagnostics page, if you see the traffic go out the LAN but nothing coming back the issue is with the client or something in between.
-danthem
opeinado
Jun 18, 2016Aspirant
Hello,
Thanks, this are screenshots:
https://drive.google.com/file/d/0BwS37xPMdkQLaDZ6eXlXVlBzU0U/view?usp=sharing
https://drive.google.com/open?id=0BwS37xPMdkQLLVBSYklqM1Vscms
https://drive.google.com/open?id=0BwS37xPMdkQLT0dfM25SZUhJcWs
https://drive.google.com/open?id=0BwS37xPMdkQLX0RydDRGMmNra0k
DaneA
Jun 19, 2016NETGEAR Employee Retired
Hi opeinado,
Kindly test if both ports 3839 and 8080 are really open on your FVS336Gv3 by using an online port checker tool like http://www.subnetonline.com/pages/network-tools/online-port-scanner.php. Fill-up the required fields then click "Scan Port." Let us know the results.
DaneA
NETGEAR Community Team
