Andrzej000
May 23, 2017Aspirant
Port Forwarding
260/5000 Good morning I have a problem with the SRX5308. I can not connect to RDP, VNC & ... via WAN. Simply redirecting ports does not work. Apparently I'm doing some...
- May 31, 2017230/5000Problem solved
Incorrect port translation was performed.
It should be done exactly on the reverse. As a service port we add port 10006, but we translate it into a 3389 rule, ie RDP port.
The previous router was suggestedRegards
And I wish you many successes
DaneA
May 23, 2017NETGEAR Employee Retired
Hi Andrzej000,
Welcome to the community! :)
Was this working fine before?
Kindly access the online port scanner here then check if ports 3389 and 5900 is really opened. If it shows "online/reachable!" it means that the port is really opened.
DaneA
NETGEAR Community Team
- Andrzej000May 23, 2017Aspirant
Good morning
Thank you for the quick reply.
These ports on the devices are active.
I connect to the devices (on the 5900 and rdp standard port 3389) without problem locally or through the WAN but the old router (Intellinet).
Port scan on the WAN side of the SRX5308 router (http://www.t1shopper.com/tools/port-scan/)- no ports open.
On the WAN side, I think it should be open ports that redirect traffic from ports 5900 ie in my case eg 10006.
I connect seamlessly through WAN to the router (using https: //) to manage it.
Since this location has two links to the other one, the other router is connected all the time and through it I have access to the local network. And I also manage roter SRX3508 through local network.
I do not quite know where to look for a solution to the problem.
With this router I have contact only for the first time so probably somewhere I make an error.
If I could pinpoint an error, I can share other current settings.
Regards - Andrzej000May 24, 2017Aspirant
No. This is a new installation.
My intention is to implement IP multicasting on the local network and VPN implementation between the (the same SRX5308) two routers through the WAN.
- Andrzej000May 26, 2017Aspirant
I reset the router to factory settings and in these settings the only action I did was to set the WAN1 port and set
security /Servicesonly:
RDP 3389 & VNC 5900.
LAN WAN Rules (ALLOW always)
Port RDP
Lan addres 192.168.1.1 redirected to 2000 port.
The stubborn router only opens one port 443 (SSL access to the router)The only opened port is the access port for the router, eg 443 via WAN.
What am I doing wrong?
Regards
- Andrzej000May 31, 2017Aspirant230/5000Problem solved
And I wish you many successes- DaneAJun 04, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know the you were able to figure it out and solved the problem. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
