Andrzej000's avatar
Andrzej000
Port Forwarding
      260/5000     Good morning I have a problem with the SRX5308. I can not connect to RDP, VNC & ... via WAN. Simply redirecting ports does not work. Apparently I'm doing some...
  • Andrzej000's avatar
    Andrzej000
    May 31, 2017
    230/5000
    Problem solved
    Incorrect port translation was performed.
    It should be done exactly on the reverse. As a service port we add port 10006, but we translate it into a 3389 rule, ie RDP port.
    The previous router was suggested
    Regards
    And I wish you many successes
ProSupport for Business
