Andrzej000
May 23, 2017Aspirant
Port Forwarding
260/5000 Good morning I have a problem with the SRX5308. I can not connect to RDP, VNC & ... via WAN. Simply redirecting ports does not work. Apparently I'm doing some...
- May 31, 2017230/5000Problem solved
Incorrect port translation was performed.
It should be done exactly on the reverse. As a service port we add port 10006, but we translate it into a 3389 rule, ie RDP port.
The previous router was suggestedRegards
And I wish you many successes
DaneA
May 23, 2017NETGEAR Employee Retired
Hi Andrzej000,
Welcome to the community! :)
Was this working fine before?
Kindly access the online port scanner here then check if ports 3389 and 5900 is really opened. If it shows "online/reachable!" it means that the port is really opened.
DaneA
NETGEAR Community Team
Andrzej000
May 24, 2017Aspirant
No. This is a new installation.
My intention is to implement IP multicasting on the local network and VPN implementation between the (the same SRX5308) two routers through the WAN.
