Andrzej000
May 23, 2017Aspirant
Port Forwarding
260/5000 Good morning I have a problem with the SRX5308. I can not connect to RDP, VNC & ... via WAN. Simply redirecting ports does not work. Apparently I'm doing some...
- May 31, 2017230/5000Problem solved
Incorrect port translation was performed.
It should be done exactly on the reverse. As a service port we add port 10006, but we translate it into a 3389 rule, ie RDP port.
The previous router was suggestedRegards
And I wish you many successes
Andrzej000
May 26, 2017Aspirant
I reset the router to factory settings and in these settings the only action I did was to set the WAN1 port and set
security /Services
only:
RDP 3389 & VNC 5900.
LAN WAN Rules (ALLOW always)
Port RDP
Lan addres 192.168.1.1 redirected to 2000 port.
The stubborn router only opens one port 443 (SSL access to the router)
The only opened port is the access port for the router, eg 443 via WAN.
What am I doing wrong?
Regards
Andrzej000
May 31, 2017Aspirant
230/5000
Regards
- DaneAJun 04, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know the you were able to figure it out and solved the problem. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
