jsroman
May 27, 2026Aspirant
Pr60x SASE Security setting missing on Insight Portal
Do not see option to turn on SASE on Insight Portal. Router GUI does show Sase Security is off. Look on Insight Portal on device-security center and don't see option to enable SASE security. Any ide...
op3c
May 27, 2026NETGEAR Expert
SASE can only be enabled from Insight, please go to Settings/Security tab for PR60X to enable SASE.
Please note that SASE is only supported by "new" Insight, the "Legacy" mode Insight won't show SASE feature. Thanks.
- jsromanMay 29, 2026Aspirant
Not seeing option under security tab. Security center tab shows: Firewall-Port Triggering-Port Forwarding-Service management and Dynamic DNS.
- op3cMay 29, 2026NETGEAR Expert
Please note that SASE enablement is available in new Insight only. If your Insight account has not been migrated to new Insight, please send request to NETGEAR support. Thanks.
