RANDOMUSER55's avatar
RANDOMUSER55
Initiate
Oct 02, 2019
xr500 settings missing
I can log into it just fine. All the areas are on the side to click. Settings is at the bottom. When I click it, I get a blank red screen. No setting to change. I click on something else and that something else shows up again just fine. When I first got the router it had settings but now there is nothing. Restarted it. Nothing. I think there was a fireware update but I don't remember if this problem started right after or not.
EDIT: Add blockers.....
  • RANDOMUSER55's avatar
    RANDOMUSER55
    Oct 10, 2019
    Yes, turns out the add blockers blocked the settings page.
      RANDOMUSER55
      Initiate
      • FURRYe38's avatar
        Ah good catch. Glad its working now.
        Enjoy. :smileywink:
  • FURRYe38's avatar
    Does this happen with different browsers? Try FireFox or Opera
  • FURRYe38's avatar
    Any progress on this?
