jsroman
May 27, 2026Aspirant
Pr60x SASE Security setting missing on Insight Portal
Do not see option to turn on SASE on Insight Portal. Router GUI does show Sase Security is off. Look on Insight Portal on device-security center and don't see option to enable SASE security. Any ide...
schumaku
May 30, 2026Guru - Experienced User
Yrs, this applies to the Insight Premium accounts. Insight Pro accounts are (at least for me) migrated. According to support, the migration of Insight Premium (should) be done during the next week(s)
jsroman double check your PR60X is also updated to v3.
On my Insight Pro installations, this update was not pushed - the targeted version insisted to remain on v2.7. Have not investigated further, so updated the device from the local Web UI instead.
