jimbo67
Sep 16, 2024Aspirant
PR60X WireGuard adding external peer such as Proton
Wireguard "server" works like a charm. Is it even possible to connect the server to another server as peer? The idea would be to have wifi guest on a vlan using proton CH wireguard "server", 3/4 An...
ErwinL
Sep 20, 2024NETGEAR Moderator
Hello jimbo67
And welcome to the NETGEAR Community! 🙂
I believe you are pertaining abut VPN connection. My understanding about what you mentioned is that you want all those authorized guest users to connect to your PR60X from outside of the office via VPN, is this correct?
Have a lovely day,
Erwin
Netgear Team
jimbo67
Sep 22, 2024Aspirant
I already have 3 clients (Phones) using wireguard to connect to the prx60.
What i wanted was to add the possibility for some of them ( wifiguest, Phone) to use the prx60 than connect to wireguard to use external vpn like proton.
I trier to see how i can add more personne on wireguard config.
But yet it dint work
