SebastianT
Nov 12, 2024Aspirant
PR60X with Wireguard VPN connection - "network neighborhood" - possible?
Hi. Router Netgear PR60X. Established Wireguard VPN connection - from the outside point to local network. Connection works, I can access computers/NAS in my local network from the outside. BUT - I ne...
c3po2
Nov 21, 2024Apprentice
You can work around this by following:
1. Make DHCP reservations on PR60X so that servers/devices on PR60X LAN IP will be static.
2. Add these static IPs to your Windows Hosts file with easy names so that you can access these remote devices by names once VPN is established.
- SebastianTNov 22, 2024Aspirant
Than you. Unfortunately, it is not very convenient, for example, when you log in from "different" computers (e.g. from a work computer, where you cannot change the settings). In my private one - I can enter it in hosts, but when I use different ones - then it is not possible, hence my question. But, as I understand, Netgear and/or Wireguard currently do not provide such an option, so you simply have to remember the numbers đ (they are static)
