joelphilippage
Mar 07, 2017Aspirant
Preventing circumvention of OpenDNS with firewall rules
Hi, I am attempting to set up my FVS318Gv2 Firewall so it will block all DNS queries that are not from OpenDNS. I was using this article for reference. To do this, I created a list of out...
- Mar 07, 2017
Mainly a stupid mistake of putting the IPs in the LAN space instead of the WAN space. Also it seems the rules should be the other way. Seems a bit backwards to the way things usually work.
Here are my final settings for future reference:
joelphilippage
- JohnRoMar 07, 2017NETGEAR Employee Retired
Hello joelphilippage,
Thank you for sharing your solution with us. I suggest editing the image you have posted since they are showing public IP addresses (assuming these are your WAN addresses). If you post your WAN address on the internet, you are taking a very big risk of exposing your network to anyone.
Thanks,
- joelphilippageMar 07, 2017Aspirant
These are OpenDNSs Wan Addresses, not ours. Thanks for making sure.
- dgordon11Jul 25, 2017Aspirant
I have a question about your configuration. I am trying to do the same thing. Do you need to have the configuration in the inbound rules also? I would thing it would just be outbound.
Thanks for posting your solution!!!!
D
- joelphilippageJul 25, 2017Aspirant
No. I found that wasn't necessary.Thanks for checking.
