joelphilippage
Mar 07, 2017Aspirant
Preventing circumvention of OpenDNS with firewall rules
Hi, I am attempting to set up my FVS318Gv2 Firewall so it will block all DNS queries that are not from OpenDNS. I was using this article for reference. To do this, I created a list of out...
- Mar 07, 2017
Mainly a stupid mistake of putting the IPs in the LAN space instead of the WAN space. Also it seems the rules should be the other way. Seems a bit backwards to the way things usually work.
Here are my final settings for future reference:
dgordon11
Jul 25, 2017Aspirant
I have a question about your configuration. I am trying to do the same thing. Do you need to have the configuration in the inbound rules also? I would thing it would just be outbound.
Thanks for posting your solution!!!!
D
joelphilippage
No. I found that wasn't necessary.Thanks for checking.
