RichardSo
May 07, 2017Follower
prevention of IP spoofing
Hi, I need a router that will conform with the requirements of my card machine providers security team. I need a firewall, this is standard on routers now. I need WPA2. This i have set up. What ...
DaneA
May 10, 2017NETGEAR Employee Retired
Hi RichardSo,
Welcome to the community! :)
It seems that you would need a firewall with comprehensive security features like the ProSECURE Unified Threat Management (UTM) appliance. The ProSECURE UTM product line is already End-of-Life (EOL). I am just giving you an idea as a basis of what you should require that would fit your network security needs.
If ever you are curious about ProSECURE UTM product line, you can access this link. Again, use this as your basis in looking for the right firewall for your network.
DaneA
NETGEAR Community Team
DaneA
May 15, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
