atiktepika
Jun 09, 2012Aspirant
Problems connecting to SQL server on Lan ( FVS318N)
Hi there, I did install without problems my new FVS318N and everything seems to be working ok except the fact that none of the computers within the lan can connect to SQL server ( except the box ho...
fordem
Jun 11, 2012Mentor
If the client computers and the system hosting the SQL server are all on the LAN side of the netgear, the problem is not caused by the netgear, but is more likely related to your ip addressing.
Second - you mention your router is at 192.168.1.1 and the netgear is at 192.168.0.2 - you obviously have two routers in the one network - this is a recipe for grief unless you have the network experience to properly configure your equipment - get rid of one.
