atiktepika
Jun 09, 2012Aspirant
Problems connecting to SQL server on Lan ( FVS318N)
Hi there, I did install without problems my new FVS318N and everything seems to be working ok except the fact that none of the computers within the lan can connect to SQL server ( except the box ho...
atiktepika
Jun 14, 2012Aspirant
Hi Fordem,
Thanks for your reply.
Removing the default "netgear.com" domain from the lan settings has fixed the problem so I guess that was it.
Right now just trying to work out a possible DNS problem since only google seems to be working :confused: but that would be a question for a different post if I can not work it out.
Thanks all for your ideas and thoughts :cool:
