atiktepika
Oct 19, 2015Aspirant
Problems running SSL VPN on windows 10 with Java and admin permissions
Dear all, I did upgrade my system to windows 10 and now I'm having issues to connect using the SSL VPN. Any time I try to connect java shows an error code 740: java.io.IOException: Cannot...
DaneA
Oct 20, 2015NETGEAR Employee Retired
Hi atiktepika,
Welcome to the community!
I am sorry to inform you that Windows 10 is currently not supported for SSL-VPN. You may want to post about your concern on the Idea Exchange For Business board. Be reminded that adding kudos to your idea will help as the development/engineering team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
DaneA
NETGEAR Community Team
Guardian2100
Jan 15, 2016Guide
Hi,
I have the same problem on our Windows 10 systems currently.
On Windows 7 it's not problem.
Is or what was the solution?
Best Regards.
