atiktepika
Oct 19, 2015Aspirant
Problems running SSL VPN on windows 10 with Java and admin permissions
Dear all, I did upgrade my system to windows 10 and now I'm having issues to connect using the SSL VPN. Any time I try to connect java shows an error code 740: java.io.IOException: Cannot...
Retired_Member
Feb 10, 2016The ONLY way that I've been able to get this to work is in a Windows 10 32-bit environment. IT WILL NOT WORK IN 64-bit. I've tested 64-bit with Firefox, IE, Chrome, Opera, and Edge - none work in 64-bit.
In 32-bit, you have to right-click Firefox, go to Properties, select the Compatibility tab, and set it to run as Windows XP Service Pack 3). You may also have to add the destination subnet to the Java allowed networks in your Java configuration window.
I hope that helps and saves you all some time and frustration. I've been there.
- aditFeb 16, 2016Mentor
The Java VPN Plugin has never worked in a 64bit OS. My understanding was due to lack of a non-IE 64bit browser.
What you can try is to download a 64bit browser and test it with the Java plugin on a 64bit OS.
Firefox just released this in December. https://blog.mozilla.org/futurereleases/2015/12/15/firefox-64-bit-for-windows-available/
Chrome, click on "Download Chrome for Another Platform" under the Download Chrome button. https://www.google.com/chrome/browser/desktop/index.html
I have not tested this since I rarely use SSL VPN anymore.
Give it a shot and let us know if it works or not.
- Retired_MemberMay 20, 2016
adit-
It doesn't work. My previous post was not clear. I used a 64-bit browser on a 64-bit Win10 and it didn't work. I did NOT use a 32-bit browser on a 64-bit OS. I understand the business reasons for not doing what I'm about to suggest, but it would be most helpful and customer friendly - create a Java-based VPN app like Fortigate, Sidewinder and Watchguard. I think I may have to switch to one of those.
-bc
