atiktepika
Oct 19, 2015Aspirant
Problems running SSL VPN on windows 10 with Java and admin permissions
Dear all, I did upgrade my system to windows 10 and now I'm having issues to connect using the SSL VPN. Any time I try to connect java shows an error code 740: java.io.IOException: Cannot...
DaneA
Oct 20, 2015NETGEAR Employee Retired
Hi atiktepika,
Welcome to the community!
I am sorry to inform you that Windows 10 is currently not supported for SSL-VPN. You may want to post about your concern on the Idea Exchange For Business board. Be reminded that adding kudos to your idea will help as the development/engineering team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
DaneA
NETGEAR Community Team
- Guardian2100Jan 15, 2016Guide
Hi,
I have the same problem on our Windows 10 systems currently.
On Windows 7 it's not problem.
Is or what was the solution?
Best Regards.
- daveb-teamlogicJan 20, 2016Aspirant
Is this still true? SSL VPN is not support in Windows 10? I just found this page after working on this for 3.5 hours this morning using all 3 of the major browsers.
- JohnRoJan 20, 2016NETGEAR Employee Retired
Hello daveb-teamlogic,
We are still having issues with some java-based browsers, see release notes of the latest firmware. Please click here.
Thanks,
- Guardian2100Jan 21, 2016Guide
When wil this be fixed? Windows 10 is out for months now.
