GaACETech
Dec 02, 2016Guide
Problems to build a LAG for trunking between two GS110T switches
We are installing a computer and printer in a new warehouse. The warehouse will have Internet access. The main office and warehouse have external IP addresses. Can someone recommend a pai...
- Dec 05, 2016
Hi GaACETech,
Having the FVS318N deployed at the main office and another one at the remote warehouse would be just fine. Since the cable modem you have seems to be a combination of wireless router and modem, it should be configured to full-bridge mode so that the WAN IP Address will be registered to the FVS318N as a requirement for VPN connection. Take note that the wireless function of the cable modem- router cannot be use once its configured to full-bridge mode.
About the simulator, it seems that the one available is for the FVS336G. You may check it here then try to navigate.
DaneA
NETGEAR Community Team
GaACETech
Dec 04, 2016Guide
Thanks so much.
I was thinking of using two of the ProSAFE FVS318N; one at the main office (replacing the older model) and one at the remote warehouse. Any problems with this?
I know that the cable provided modem with Wi-Fi will need tweeking to turn off Wi-Fi and maybe turn on/off bridging.
Did I see on the website a simulator for there software and hardware?
(Sorry. My typing is under the influence of cold medicines... )
Thanks, Darryl
DaneA
Dec 05, 2016NETGEAR Employee Retired
Hi GaACETech,
DaneA
