DA2B
Jun 11, 2016Follower
Product replacement for FVS336GV2
Hello the community, I'm searching an actual product able to replace the FVS336GV2, I don't need WIFI, just 2 LAN connection and the most important is the VPN possibility with the old NETGEAR ProSaf...
JohnRo
Jun 16, 2016NETGEAR Employee Retired
Hi DA2B,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
