kj6eo's avatar
kj6eo
ProSafe FVS318G Between TWC Cable Modem and Linux Server
Hello and thanks for reading my post.  I'm switching over to TWC Business Class with 5 Static IP's.  I had them put their modem in Bridge Mode.  So I have TWC Modem > ProSafe FVS318G > ETH0 (Linux Server w IPTables FW) ETH1 > LAN.  I want to add the ProSafe as an extra layer of security before my Linux Server.  Although I have a Linux background, I'm not familiar with the Netgear VLAN firewalls. What's the correct way to get my Static IP through the ProSafe to my Linux Server.  Thank you in advance for your suggestions!
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello kj6eo,
    Welcome to the community!
    The FVS318G does not have VLAN functionality (the FVS318Gv2 does). For you to achieve your goal, VLAN is not necessary what your. Instead, use Classical Routing (see page 33) in which you will have to specify the entire IP, subnet and gateway to the server. Doing this setup will kill the NAT so there will be no protection. The main question will be, do you really need to have a public IP on the Linux Server or not. Because, if your goal is to let the Linux Server control the traffic coming in and out then my suggestion is just to use DMZ (see page 49) instead.
    I hope this helps, let us know.
    Thanks,
    • kj6eo's avatar
      kj6eo
      JohnRo - Thank you for replying to my post.  I do have the FVS318Gv2.  My Linux Server has an IP Tables Firewall running on it.  I could connect the cable modem directly to the Linux Server.  However, I bought the FVS318Gv2 as an extra layer of security.  I have 5 static IP's.  They are currently set up as follows:
      64.xxx.xxx.73     TWC Cable Modem
      64.xxx.xxx.74     FVS318Gv2
      64.xxx.xxx.75     Linux Server
      64.xxx.xxx.76     Future Use
      64.xxx.xxx.77     Future Use
      64.xxx.xxx.78     Future Use
      Yes, once I put the WAN Settings of the FVS318Gv2 into Classical IP mode, I did notice that NAT was disabled and I could no
      longer surf.  I'm using a Laptop right now in place of the Linux Server for testing.  I need to get 64.xxx.xxx.75 through the FVS318Gv2 to the Linux Server.  Not just a pass through, I want to use the packet filters in the FVS318Gv2 also.  I've read the
      manual, but I don't seem to be having any success.  Would you have any more suggestions?
      • DaneA's avatar
        DaneA
        Hi kj6eo,
        I currently do not have an FVS318Gv2 to check.  However, kindly check if the FVS318Gv2 has the capability to add secondary WAN Addresses just like in the image below:
        Note: The image above is from the web-GUI of the FVS336Gv3.
        I look forward to your response.
        DaneA
        NETGEAR Community Team
ProSupport for Business
